Common diode symbols
Source: InternetPublisher:刘德华河北分华 Keywords: diode voltage regulator Updated: 2021/12/28
diode symbol
Figure 1: Ordinary diodes, the first one is the domestic standard drawing method,
Figure 2 Bidirectional transient suppression diode.
Figure 3 shows photosensitive or photodiodes and light-emitting diodes respectively.
Figure 4 shows a varactor diode, and Figure 5 shows a Schottky diode.
Figure 6 is a constant current diode.
Figure 7 shows the Zener diode.
The traditional drawing method still has a circle, which is basically no longer used now.
- How do Zener diodes protect circuits?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- FPGA Features and Architecture
- Causes and solutions for noise in digital Class D amplifiers
- Analysis of the working principle of CMOS/CCD image sensor
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Make a flameless electronic candle using simple electronics and LEDs
- Structural diagram and function of sliding resistor
- What is the difference between high-side and low-side resistive current sensing
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Can you use the new high-voltage thyristors and diodes?
- Littelfuse Low Capacitance TVS Diode Array Analysis
- VEMD6010X01 reference design circuit | PIN photodiode application circuit
- Quasi-circuit--Miscellaneous talk on rectification (2)
- Mobile phone shielding circuit that can be used as a charger
- base amplitude modulation circuit
- Lighting light and dark conversion circuit
- Improved multivibrator circuit c
- Fast response circuit b when controlled by transistor
- Dimming circuit with capacitor and diode
