Microcontroller control circuit
Source: InternetPublisher:三岁就很酷 Keywords: Microcontroller power supply communication power supply communication Updated: 2021/01/06
![Microcontroller control circuit](http://www.eeworld.com.cn/circuit/upload/88c2cb9b68e8a1990ef75cd3ab932139/fab26105947b22cb4e677db948c05d72.jpg)
Its main function is to complete the detection of the instantaneous value and peak value of overvoltage, the detection of the number of overvoltages, the detection of power supply output voltage and current, and display the size of each detection value through keyboard operation; at the same time, through the MAX485 interface and the host The machine realizes communication, and when there is overvoltage, the control circuit starts each power supply to protect the power supply itself.
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Practical and convenient fax machine power supply control circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- The constant current source composed of two transistors can drive high power
- Detailed explanation of 5v charger circuit diagram
- Principles and precautions of active discharge circuit
- Voltage-current converter constructed with XTR110
- CNC regulated power supply production
- Converting a lithium battery charging board into a constant voltage and current charger
- A low-cost, high-reliability battery charger for electric vehicles
- Importance of Voltage Supervisors and Output Topology Selection
- Microcontroller buzzer control program and drive circuit diagram
- Reset circuit design of the smallest microcontroller system
- Analysis of internal reset circuit diagram of microcontroller
- Excellent performance household inverter power supply circuit
- Two types of negative voltage generation circuit diagrams of single-chip microcomputer
- Power circuit with smoothing filter capacitor
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- M62430 typical applications
- MAX705, 706, and 813L constitute a single-chip microcomputer monitoring circuit
