Double interlock control circuit of three-phase asynchronous motor
Source: InternetPublisher:aerobotics Keywords: Power supplyAC/DC Updated: 2020/07/21
![Double interlock control circuit of three-phase asynchronous motor](http://www.eeworld.com.cn/circuit/upload/8067c9f402bfd1c6afea97672c06b8ee/aa91bb16f453e1bc5173835cf0c3c007.jpg)
The advantage of this circuit is that if you want to reverse the forward running motor, you don't have to press the stop button SB1 first, just press the reverse start button SB3 directly; of course, the same is true from reverse running to forward running. This circuit has dual electrical and mechanical "interlocking" functions, which not only improves the reliability of control, but also can realize forward-stop-reverse-stop control and forward-reverse-stop control. control.
- Sharing layout and tips for multi-rail power supply design
- 5 Converter Topologies for Integrated Solar and Storage Systems
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- What kind of circuit is a voltage regulator circuit?
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LED rechargeable flashlight circuit diagram
- Dual forward converter schematic diagram
- An ultra-low output voltage regulator
- Car power 1.5V-12V six-speed converter
- Principle of single live wire power taking circuit
- Sense amplifier circuit
- Two-wire remote AC electronic thermostat (gas or oil furnace control)
- Three-phase phase loss alarm light circuit
- Power circuit of STR5412
- Interface circuit diagram for controlling AC load
- 3v to 5v circuit diagram
- Power circuit of LBO-522 dual trace oscilloscope
- Timing switch AC power circuit
- Recording level power supply circuit
