An electric motor energy consumption braking circuit diagram
Source: InternetPublisher:奥特man123 Keywords: Power DC/DC Updated: 2021/06/03
To speed up the parking of equipment driven by electric motors, mechanical friction is generally used for braking. Improper operation during the braking process will cause detonation.
The principle of energy consumption braking is that after the stator winding is powered off, the two-phase stator winding is immediately connected to a DC power supply, so a static magnetic field is generated in the stator winding; the rotor rotates in this magnetic field to generate an induced electromotive force, and the rotor current is equal to The torque generated by the fixed magnetic field prevents the rotor from continuing to rotate, thus producing a braking effect and causing the motor to stop quickly.
This circuit is simple and reliable, suitable for motors below 5kW. Working process: Press the start button QA, the contactor IC coil is energized, the motor rotates, and the capacitor C is charged at the same time. When parking, press the TA button, the contactor IC loses power and disconnects the motor. The capacitor C has a resistance of 3kΩ to the coil. The high-sensitivity relay J discharges, causing J to pull in, and the 2C contactor coil is powered to pull in, thereby performing DC energy consumption braking. After a certain period of time, the capacitor C is completely discharged, and the relay J is released, and the braking ends at this time. Selecting the capacity of capacitor C can change the length of braking time.
The following is a simple and practical electric motor energy consumption braking circuit diagram.
- Build a simple buck-boost regulator and test it on a breadboard
- ISO113 circuit that can reduce power consumption
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Transformerless AC-DC constant current LED driver circuit
- Parallel DC regulated power supply circuit diagram
- Principles and precautions of active discharge circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- Car Audio Power Supply
- LM317T voltage regulation adjustable circuit diagram explanation
- Importance of Voltage Supervisors and Output Topology Selection
- DC output DC converter circuit
- Clock switching circuit and its precautions
- Circuit diagram for using an ordinary TV remote control to control switches of other home appliances such as light bulbs and fans
- Uninterruptible power supply circuit diagram composed of MIC5158
- Power circuit of STR5412
- Signal simulator circuit diagram
- Dual-purpose voice-activated switch circuit diagram
- Three-way DC-DC converter circuit
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
