Motor forward and reverse control wiring diagram (2)
Source: InternetPublisher:刘德华河北分华 Keywords: Power supply other power circuits Updated: 2021/06/04
This circuit is a motor reversible operation control circuit diagram based on the motor forward and reverse control wiring diagram (1). This circuit shares the AC contactor wiring diagram to check whether the main circuit wiring is correct. In order to ensure that the phase sequence of the motor can be reliably changed when the two contactors operate, the upper wiring of the contactor should be consistent during wiring. The lower port of the contactor is phase-modulated. Then, after checking that the wiring is correct, conduct a power test. To prevent accidents during the power test, the motor wiring should be disconnected first. As shown below.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Fabrication of multi-cell lithium battery charging circuit
- Basic circuit description of adjustable voltage regulator LM317
- ISO113 circuit that can reduce power consumption
- Detailed explanation of 5v charger circuit diagram
- Dual forward converter schematic diagram
- Charging control circuit made by solar energy
- Power supply circuit that can reduce LM317 ripple
- Integrated regulated power supply with continuously adjustable output voltage
- Practical constant current charger-----Constant current charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
