Circuit design of thermal release human body infrared module temperature acquisition system
Source: InternetPublisher:念念Brown Updated: 2021/11/06
The human body infrared sensing module circuit is mainly composed of human body infrared sensor, Fresnel lens and special chip BISS0001. When someone appears in its detection area, the sensor can detect the signal and transmit the signal to the microcontroller. The microcontroller will then turn on the device or put the electrical equipment in the room in an openable state according to the actual situation. In addition, regarding the lighting situation in corridors and hand washing, when someone passes by at night, the human body's infrared sensor detects the person and turns on the corridor lights or bathroom lights. The thermal release human body infrared module circuit is shown in Figure 2.
Figure 2 Pyroelectric human body infrared circuit diagram
The pyro-infrared special chip BISS0001 is used in the circuit. It is a digital-analog hybrid special-purpose integrated circuit composed of an operational amplifier, a voltage comparator, a state control, a delay time timer and a blocking time timer. The internal circuit is shown in Figure 3 . When the infrared rays radiated by the human body are focused on the detection element of the pyroelectric infrared sensor through the Fresnel lens, the sensor in the circuit will output a voltage signal, and then the signal first passes through a band-pass filter, the upper limit of the filter The cut-off frequency is 16 Hz, and the lower limit cut-off frequency is 0.16 Hz.
Figure 3 BISS0001 chip internal circuit diagram
Since the detection signal voltage output by the pyroelectric infrared sensor is very weak (usually only about 1 mV), and it is a changing signal, at the same time, the function of the Fresnel lens makes the output signal voltage appear in the form of pulses (the pulse voltage is 0.1~ (about 10 Hz), so the voltage signal output by the pyroelectric infrared sensor should be amplified twice through operational amplifiers OP1 and OP2. After being processed by the bidirectional amplitude detector composed of voltage comparators COP1 and COP2, the effective trigger signal Vs is detected to start the delay timer.
The output signal Vo is connected to the microcontroller for detection. When there is someone, it outputs a high level of 5 V. When the person leaves, it is reset to 0 V after a delay for a period of time to facilitate the control of the main control circuit. The circuit design puts the chip in a re-triggerable state to suit actual classroom conditions. The working process of repeated triggering: In the repeatable triggering working mode, when Vc = "1" and A = "1", Vs can repeatedly trigger Vo to be in the effective state, and can cause Vo to remain in the effective state during the Tx cycle. During the Tx time, as long as Vs jumps upward, % will continue to extend - one Tx cycle from the moment when Vs jumps upward; if Vs remains in the "1" state, Vo will always remain in the valid state; if Vs remains in the " 0" state, Vo returns to the invalid state after the end of the Tx cycle, and also within the blocking time Ti, any change in Vs cannot trigger Vo to become the valid state.
- How to Create a Solar Electricity Solution
- Water Softener
- How to make a metal detector using the TDA0161 proximity switch chip?
- Electronic dice circuit based on CD4017
- Detailed explanation of the working principle of the clapper activated optical circuit
- How to Make a Digital Taxi Meter Using Arduino
- Tutorial on making a handheld Geiger counter
- Design a pet NFC timer feeder
- Analysis of the circuit principle of ZX5-630 welding machine
- How to use the MP3 player from CATALEX
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
- Three-digit display capacitance test meter circuit module design - photoelectric display circuit
- Advertising lantern production circuit design - signal processing electronic circuit diagram
京公网安备 11010802033920号
