Capacitive sensor system circuit
Source: InternetPublisher:supremeOne Keywords: system circuit capacitive sensor sensor system electric field Updated: 2021/07/30
This circuit diagram shows the electric field configuration of a capacitive proximity sensor in the form of a capacitive reflector. It consists of a sensing electrode driven by an AC voltage, creating an electric field near the electrode. Material entering this electric field will be induced by the magnetic field on the resistor between the sensing electrode and electrical ground.
- A very convenient small power supply circuit to share
- Driving circuit of switching power supply field effect tube
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Introduction and principle analysis of switching regulated power supply
- Energy-saving motorcycle rectifier regulator
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Principles and precautions of active discharge circuit
- How to use SBR to improve power conversion efficiency
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Practical constant current charger-----Constant current charger
- Power circuit of STR5412
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- Timing switch AC power circuit
- Class A power amplifier power circuit
- Music power circuit
- Common power circuits and applications 06
- Common power circuits and applications 01
- AC-DC conversion power supply-inverter power supply circuit
- Nine-speed adjustable DC power circuit
