Automobile headlight automatic controller circuit composed of 555
Source: InternetPublisher:拿铁三分糖 Updated: 2021/01/19
17:00:12As shown in the figure is the automatic control circuit of automobile headlights. The controller consists of a monostable delay circuit (IC1, Rl, R2, RD, C1), a multivibrator (IC2, R3, R4, C2), an integrated voltage stabilizing circuit IC3 (7812), and a V-MOS power drive tube. It is composed of BG2, BG3, etc., which drive the two headlights of the car respectively. The power supply of the controller is powered by the car battery +24V. After being stabilized by IC3, it provides a DC voltage of VDD=+12V to IC1 and IC2.
When there is no vehicle going in the opposite direction in front, the photoresistor RD is high-impedance because it is not exposed to light. The corresponding IC1 is reset because pin ② is high level, and pin ③ outputs low level. This level puts IC2 in a reset state because pin ④ is at low potential. The low level output by pin ③ turns off BG1, turns on BG2 and BG3, and lights up the two headlights.
When there is a vehicle traveling in the opposite direction in front, RD is low-impedance due to being illuminated by the lights of the other vehicle. IC1 is set because pin ② is low level (1/3VDD), and pin ③ outputs high level. The level causes IC2 to start oscillating because the ④ pin is high level, and outputs a square wave signal with an oscillation frequency of f=1.44/(R3+2R4)C: (about 40Hz). At this time, BG1 alternately turns on and off with the high and low levels of the square wave, and correspondingly, BG2 and BG3 alternate between turning off and on, causing the two headlights to flash brightly and darkly. If the light disappears, C1 is charged through R2. When the voltage on C1 is charged to 2/3VDD, IC1 is reset. The charging time of C1 is the delayed flashing time of the headlight td=1.1R2C1. If the delay time is up and RD is still not illuminated, IC1 is in a low level stable state. This low level resets IC2 and the two headlights light up again.
- Voice Control Toy Car
- NE555 makes a pleasant doorbell
- NE555 multi-purpose delay switch power socket
- 555 multifunctional refrigerator power socket circuit (1)
- Four basic circuits of 555 monostable trigger
- 555 exponential voltage controlled oscillator circuit
- 555 Electronic Scarecrow Circuit
- 555 controller circuit for automatically changing ten wind speeds
- 555 simple washing machine timer circuit
- 555 calculator/stopwatch converter circuit
- NE555 time base integrated circuit diagram
- 50% duty cycle 555 circuit
- Self-stopping hypnotic device circuit diagram
- Double-key touch switch circuit diagram using 555 time base circuit
- Pulse width modulation circuit diagram based on 555 base time
- Electric bell sound delayer schematic diagram
- Integrated circuit timer 555 internal structure circuit diagram
- Circuit diagram based on 555 base time astable working mode
- 555 long learning time reminder circuit
- 555 Electronic disinfection circuit using ozone tube
