14-bit 125MSPS quad-channel ADC circuit diagram (enhanced SNR performance through back-end digital summation)
Source: InternetPublisher:黄土马家 Updated: 2020/08/06
Circuit functions and advantages
The circuit shown in Figure 1 is a simplified diagram of a 14-bit, 125 MSPS quad ADC system that uses back-end digital summation to improve the signal-to-noise ratio (SNR) from 74 dBFS for a single-channel ADC to 78.5 dBFS for a quad-channel ADC. This technology is particularly suitable for applications requiring high SNR, such as ultrasound and radar, and takes advantage of modern high-performance, low-power, quad-channel pipelined ADCs.
This circuit uses the basic principle that uncorrelated noise sources are summed on a root sum of squares (rss) basis, while signal voltages are summed on a linear basis.
Figure 1. Basic block diagram of summing four parallel ADCs for higher SNR.
Circuit description
The input to each ADC consists of a signal term (VS) and a noise term (VN). Summing the four noise voltage sources gives the total voltage VT, which is the linear sum of the four signal voltages plus the roots of the square sums of the four noise voltages, for example:
Since VS1 = VS2 = VS3 = VS4, the signal is effectively multiplied by 4, while the converter noise - which has an equivalent rms value - is only multiplied by 2, so the signal-to-noise ratio increases by a factor of 2, or 6.02 dB. Therefore, the 6.02 dB SNR increase is the result of one additional bit of effective resolution resulting from summing four similar signals. Since SNR (dB) = 6.02N + 1.76 dB, where N is the number of bits, thus
Table 1 shows the theoretical SNR value obtained by summing the outputs of multiple ADCs. For convenience, one should obviously choose to sum the four ADCs. Certain critical situations may require more ADC summing, but this depends on other system specifications (including cost) and available board space.
Table 1. Relationship between increasing SNR and number of ADCs Number of ADCs SNR increase (dB)
The ideal SNR for a 14-bit ADC is (6.02 &TImes 14) + 1.76 = 86.04 dB The AD9253 datasheet specifies a typical SNR of 74 dB, but it produces an ENOB of 12 bits.
The circuit shown in Figure 1 integrates a passive receiver front end and consists of four analog input channels. The device used is the 14-bit, 125 MSPS four-channel analog-to-digital converter AD9253.
This circuit accepts a single-ended input and converts the input to a differential signal through two wide-bandwidth (3GHz) M/A-COM ETC1-1-13 baluns with an impedance ratio of 1:1 in a double-balanced configuration, as shown in Figure 2 Show.
Figure 2. Input simulation summation network
All four ADC inputs are connected on the secondary side of the balun configuration. There is no gain in the circuit, and each analog input pair has a simple filtering function to reduce residual kickback signals that may be fed back to adjacent ADC channels.
- Share a board game electronic dice circuit
- Build an Automatic Candy Vending Machine
- How to Build a Simple Yet Powerful MP3 Player
- Design of a drone wildlife counting system using FOMO object detection algorithm
- Homemade CNC plotter
- Designing a Simple Solar Voltage Regulator PCB
- How to Use the Radio to Record Phone Calls Automatically
- Analysis of the circuit principle of ZX5-630 welding machine
- Circuit diagram of intermittent cockroach killer
- Easy-to-make integrated circuit signal tracker circuit
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
- Three-digit display capacitance test meter circuit module design - photoelectric display circuit
- Advertising lantern production circuit design - signal processing electronic circuit diagram
京公网安备 11010802033920号
