Additional circuit diagram for measuring voltage with 555 frequency meter
Source: InternetPublisher:小胖友 Updated: 2021/04/03
555 additional circuit for measuring voltage with frequency meter
As shown in the figure, this circuit consists of 555, an astable multivibrator composed of R1, RP1, and C1, and an attenuation resistor. As a voltage-frequency converter, it can measure DC voltages from 0 to 5V.
Potentiometer RP1 determines that when the input voltage is 0V, the frequency meter reading is 0Hz; RP2 is used to adjust the frequency meter reading to 50Hz when the input voltage is 5V, that is, full range adjustment. This additional circuit enables measuring frequency instead of measuring voltage.
Frequency meter, also known as frequency counter, is an electronic measuring instrument specially designed to measure the frequency of the signal being measured. The frequency meter mainly consists of four parts: time base (T) circuit, input circuit, counting display circuit and control circuit.
- Variety of light-controlled electronic birds
- The power-on delay output low level circuit composed of NE555
- Monostable trigger driving circuit made of 555 time base circuit
- 555 infrared transmitter circuit
- 555 voice-activated duty alarm circuit
- 555 production line automatic counting device circuit
- 555 wide range adjustable timer circuit
- 555 controller circuit for automatically changing ten wind speeds
- 555 color changing electronic corsage circuit
- 555+5V voltage conversion to earth 15V voltage source circuit
- NE555 time base integrated circuit diagram
- 50% duty cycle 555 circuit
- Self-stopping hypnotic device circuit diagram
- Double-key touch switch circuit diagram using 555 time base circuit
- Pulse width modulation circuit diagram based on 555 base time
- Electric bell sound delayer schematic diagram
- Integrated circuit timer 555 internal structure circuit diagram
- Circuit diagram based on 555 base time astable working mode
- 555 long learning time reminder circuit
- 555 Electronic disinfection circuit using ozone tube
京公网安备 11010802033920号
