Light control, single button switch wall base circuit
Source: InternetPublisher:子丑寅卯 Updated: 2016/11/24
During the day, due to the high indoor brightness, the switch load (relay) does not work when the button is pressed. At night or when the indoor brightness is dark, the load can start working by pressing the button switch. This means that whether the load starts after pressing the button depends on the brightness of the room. Once the load is started, regardless of the brightness of the room, However, pressing the key switch again can turn off the load. PR is the brightness control and adjustment resistor. You can also increase or decrease the resistance value as needed. The photoresistor should be installed in a position that is not blocked when the button is pressed (if possible, try to install it in a place that cannot be artificially blocked). Otherwise, when the indoor brightness is high, the load will start accidentally after pressing the button.
![光控、单按键开关壁座电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/4c6994d2-3c63-11ec-9e95-086126841eb8.gif)
Latest Control Circuits Circuits
- How to choose the right level of integration to meet motor design requirements?
- Controlling LEDs with Node-RED in Raspberry Pi
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Introduction to the internal structure of the Delta winding motor
- Squirrel cage asynchronous motor reverse braking control circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of the principle of automatic power-off switch during power outage
- Magnetic door and window anti-theft alarm
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
