Thyristor zero-crossing detection circuit diagram
Source: InternetPublisher:消失的歌 Keywords: Thyristor detection circuit diagram zero-crossing detection circuit capacitor Updated: 2020/06/03
The moment when the thyristor is put into the capacitor , that is, the moment when the thyristor is turned on, must be the moment when the amplitude and phase of the power supply voltage and the residual voltage of the capacitor are the same. Because according to the characteristics of the capacitor, when the voltage applied to the capacitor changes stepwise, an inrush current will occur, which will damage the thyristor and bring adverse effects such as high-frequency oscillation to the power system. Therefore, a thyristor zero-crossing detection circuit is designed to solve the problem of residual voltage measurement. The thyristor zero-crossing detection circuit is shown in Figure 3.
When the power supply voltage is equal to the residual voltage of the capacitor, the voltage on the thyristor is zero, and the photocoupler will output a falling edge negative pulse to the INT0 and INT1 pins of the microcontroller. If the controller input command exists at this time, this pulse will pass through a In a series of steps, a pulse train is generated to trigger the thyristor to ensure the conduction of the thyristor and the capacitor is put in smoothly; when the power supply voltage is not equal to the residual voltage of the capacitor , the voltage on the thyristor is not zero, the optocoupler is turned on, and is connected to the INT0 and INT0 of the microcontroller. INT1 is at high level. If this situation is set in the software, no trigger pulse will be generated, and the thyristor will be in the off state.
- The basic principles of power supply design. What are the key components of a power supply?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Schematic diagram of car cigarette lighter to USB power port
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Single-power supply circuit for ISO122P/ISO124
- Op amp power supply decoupling bypass measures
- Dynamic power supply for power amplifier controlled by thyristor
- A novel and practical DC low voltage stabilized power supply
- LM317 regulated power supply
- How to Select Modular EMI Filters for AC-DC Converters
- Thyristor silicon stack protection circuit c
- Voltage controlled sawtooth oscillatorb
- Voltage controlled sawtooth oscillatora
- Projector lamp AC automatic voltage regulation circuit circuit diagram
- One of the thyristor turn-on delay circuits
- Thyristor discharge machine circuit
- Music control lantern circuit
- Thyristor overcurrent protection circuit one b
- Thyristor controlled AC stabilized power supply circuit 2
- Thyristor zero trigger AC regulated power supply circuit
