Projector lamp AC automatic voltage regulation circuit circuit diagram
Source: InternetPublisher:闪电杰克 Keywords: Circuit diagram voltage regulating circuit thyristor Updated: 2020/01/16
In order to stabilize the brightness of the projection lamp L, a thyristor AC automatic voltage regulation circuit is used in the circuit . For this reason, the thyristor T5 is connected from a diagonal line of the AC bridge. Its trigger pulse is equivalent to the equivalent resistance of the unijunction transistor VT1, VT2 and the photosensitive three-pole VT3. When the light of the projection lamp changes due to changes in the power supply voltage, the resistance of the phototransistor changes, and the voltage phase of the control single-junction transistor also changes, thereby causing the pulse phase of the triggering thyristor to move and increase or decrease the thyristor conduction time. The voltage on L is kept approximately constant, and the brightness of the projection lamp is also kept approximately constant, making the light stable.
- How to use LM317 as a switch to turn power load on and off
- LM350 adjustable voltage regulated power supply circuit diagram
- What does power ripple mean? How big is the DDR power ripple requirement?
- How does a step-down switching regulator use a series transistor or a power MOSFET?
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Analysis of the working principle of switching regulator
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Detailed explanation of 5v charger circuit diagram
- Switching power supply circuit composition and function introduction of each part
- Boost drive circuit composed of RT8450
- Plastic sealing machine circuit composed of unidirectional thyristor
- Thyristor triggered interface circuit b
- Voltage controlled sawtooth oscillatorb
- Thyristor cut-off delay circuit 6
- Thyristor cut-off delay circuit part 5
- Thyristor magnetizer circuit 2
- Interface circuit between thyristor and MFC8070 zero-voltage integrated trigger
- DC power supply non-stop switching circuit using thyristor
- Thyristor controlled AC stabilized power supply circuit 3
- Thyristor zero trigger AC regulated power supply circuit
