Home >
Power Circuits >Charging Circuits > 6V battery automatic charger circuit for emergency lights
Source: InternetPublisher:消失的歌 Updated: 2019/10/18
The 6V battery-powered emergency lights that appear on the market come with too simple a charger, which can cause serious heat and burn easily after long-term use. It is also easy to overcharge the battery during charging, causing the electrolyte to dry out prematurely and shortening the battery life. In response to this shortcoming, the author changed it into an automatic charger. After more than half a year of use, the effect is good. The circuit is shown below:
Brief description of the principle: IC provides the base voltage for the base of T1, and the relay J realizes the self-locking and automatic switching of the switch K. Power outage. After connecting the battery, press K, the power indicator light L lights up, and J is powered on at the same time. K is self-locked by its contact J-0, and charging begins. At this time, the emitter voltage of T1 is low due to the lack of battery power. At (7.5V+0.65V), T1 is cut off, T2 is also cut off, and they have no effect on T3. When the battery voltage is charged to 7.5V, the emitter voltage of T1 is 7.5V+0.65V, T1 is saturated and turned on, T2 is also turned on, the base voltage of T3 drops and is turned off, J loses power and is released, J-0 is disconnected, charging stop. Indicator light L goes out. Batteries with different voltages can also be charged by adjusting W. Diode D in the circuit is an isolation diode, which can prevent reverse discharge of the battery. Component selection: R is the charging current limiting resistor, which can be selected between 5 and 10Ω. There are no special requirements for other components. All components can be overlapped on a plastic box, and the IC does not need a heat sink. Debugging: Short-circuit K and adjust W so that the IC output voltage is 7.5V, the battery's full voltage.
![应急灯用6V电瓶自动充电器电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/66eaca3e-3c63-11ec-823b-086126841eb8.jpg)
Latest Power Circuits Circuits
- The basic principles of power supply design. What are the key components of a power supply?
- Single-power supply circuit for ISO122P/ISO124
- Use pulse width modulation to get a precise output voltage
- Detailed explanation of 5v charger circuit diagram
- How to use SBR to improve power conversion efficiency
- Low cost and high performance LED constant current power supply
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Voltage-current converter constructed with XTR110
- USB power socket using the car battery
- Circuit diagram explanation: simple switching power supply circuit diagram
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
