Inductorless analog relay circuit
Source: InternetPublisher:风向西瓜 Updated: 2018/06/02
This article introduces a non-inductive analog relay, the circuit principle of which is shown in the figure below.
In the figure, the 220V power supply supplies bias to Q4 and Q3 in turns in the positive and negative half cycles through the load RL, R1, D1~D4, and ZD1; at the same time, it provides power to the photocoupler Q1 through R3, D5~D8. When the front-stage TTL circuit outputs a high-level signal, the photocoupler is turned on during the positive half cycle of the mains power, so a voltage drop occurs across R5, triggering the SCR to turn on, and the load RL is powered to work. The entire circuit functions like a relay, but does not generate reverse induced voltage, thus avoiding the possibility of the load being damaged by high back voltage breakdown. C1 and R6 are pulse absorption components, and R3 plays a current limiting role. In order to avoid the 90° phase between the voltage of the thyristor and the power supply of the photocoupler when RL is an inductive load, the power supply of the photocoupler in this circuit is taken from the anode of the SCR and not directly from the mains power supply.
Latest Control Circuits Circuits
- How to use a microcontroller to control a servo motor?
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Analysis of the working principle of car garage door lights
- Model rocket launch controller circuit
- A simple door handle touch alarm circuit
- An automated model railroad layout project using a microcontroller
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Add one more component to improve the phase failure protection function
- Motorcycle anti-theft device circuit design
- Password type motorcycle anti-theft device
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
