Multifunctional low-power RX130 32-bit microcontroller, do you know?
Source: InternetPublisher:newrudeman Keywords: renesas microcontroller Updated: 2021/09/26
What is the versatile, low-power RX130 32-bit microcontroller? What does it do? Mouser Electronics, a global authorized distributor of the latest semiconductors and electronic components, is stocking Renesas Electronics' RX130 series of 32-bit microcontrollers from now on. The RX130 microcontroller adopts new capacitive touch proprietary technology to improve sensitivity and durability. It is ideal for devices designed with non-traditional touch materials or devices that need to work in humid or dirty environments, such as human-machine interfaces, Home kitchen and bathroom, motor control and factory applications.
The Renesas RX130 microcontroller supplied by Mouser Electronics is equipped with a 50-DMIPS RX core and up to 512 KB of flash memory, so code can be executed immediately without waiting. In addition to allowing memory expansion, this series of microcontrollers also increases the package to 100 pins to improve performance and improve compatibility with the RX231/RX230 series touch microcontrollers.
This series of low-power RX130 microcontrollers consumes only 0.37-µA current in sleep mode and only takes 4.8 µs to return to working state. It integrates a 36-channel capacitive touch sensor with fast response speed and powerful functions. It is suitable for various applications. A touch application. This series of microcontrollers also provides a dual-channel digital-to-analog converter (DAC) and a 12-bit analog-to-digital converter (ADC), which can complete conversion within 1.4 μs.
The RX130 32-bit microcontroller is supported by a variety of development tools, which are also available from Mouser Electronics. The RX130 capacitive touch evaluation system is a modular development platform that can demonstrate various touch functions of a microcontroller. The system has a CPU base board, a self-capacitance application board and a mutual capacitance application board, which can be used to test functions such as sliders, scroll wheels and proximity touch.
The RX130 Starter Kit is a compact development platform that includes bundled code, Renesas' Eclipse-based e2 studio integrated development environment and C/C++ compiler. With this starter kit, developers can start evaluating the RX130 microcontroller right out of the box. The above is the analysis of the multi-functional and low-power RX130 32-bit microcontroller. I hope it can be helpful to everyone.
- Schematic diagram of car cigarette lighter to USB power port
- In-depth analysis of DC-AC converter inverter
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- What kind of circuit is a voltage regulator circuit?
- ISO113 circuit that can reduce power consumption
- Driving circuit that controls LED brightness using PWM signal
- Voltage-current converter constructed with XTR110
- Adjustable regulated power supply with current limiting protection
- Car power 1.5V-12V six-speed converter
- Battery powered switching circuit diagram
- Negative voltage generation circuit diagram
- Minimum system interface circuit based on AT89C52 microcontroller
- DC 12V to AC 100V inverter power supply circuit design
- Laser power circuit
- Two types of negative voltage generation circuit diagrams of single-chip microcomputer
- Power circuit with smoothing filter capacitor
- IR2130 combined with microcontroller and SLE4520 for three-phase frequency conversion system diagram
- Use MC34063 as a 12-volt programming power supply for single-chip microcomputer
- Optoelectronic interface circuit between single-channel DA chip DAC0832 and microcontroller
- Microcontroller universal digital tachometer circuit
