A miniature FM wireless microphone circuit
Source: InternetPublisher:两手空空 Updated: 2015/07/02
The miniature FM wireless microphone circuit uses a capacitive three-point oscillator, which is simple, reliable and easy to start. The amplifier circuit composed of BG1 amplifies the weak sound signal detected from the small condenser microphone, reaches a certain amplitude, and then sends it to the capacitive three-point oscillator composed of BG2 to modulate the carrier signal generated by BG2, and finally outputs it from the antenna. The circuit adopts diode voltage stabilization technology, which can make the circuit work more stably. The circuit is as shown below: Component selection:
BG1 uses 2SC9014 equivalent power transistor. BG2 uses high-frequency and high-power transistors such as 2SC9018, which requires β ≥ 100. If the amplification factor is too high, it will easily cause instability, and if it is too low, it will be detrimental to the vibration of the circuit. The MIC uses a miniature ultra-thin condenser microphone. L1 is obtained by wrapping 8 turns of Φ51mm high-strength enameled wire on the ballpoint pen core. It resonates in parallel with C4 and reaches about 100MHZ. The antenna uses a flexible wire about 80mm long. The entire circuit can be built on a circuit board with a size of about 3×2mm. An ordinary FM radio should be able to clearly monitor slight sounds within 5M around the microphone at a distance of 100M. In order to work stably for a long time, the circuit is powered by a 3V battery, and the whole machine consumes 8-10MA current.
![一微型调频无线话筒电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/95169e6e-3c63-11ec-add0-086126841eb8.gif)
Latest Communication Circuits Circuits
- Types/advantages and disadvantages of repeaters, how do repeaters work?
- TA7792 Medium Wave Radio Circuit Diagram
- FMA9901A FM broadcast dedicated antenna
- QMR1/QMR2 AM/FM 868/433.92 MHz Receiver Module
- Eight-way remote control transmitter circuit using CS901
- RF2909 GMSK/QPSK/DQPSK/QAM 915 MHz Transmitter
- Rolling code radio transmitter circuit (HSC360/TDA5100)
- MC33493/D OOK/FSK 928~902 MHz/434~315 MHz dual frequency transmitter
- TX500 ASK 1 GHz~100 MHz Transmitter Module
- AT86RF211 FSK 950~400 MHz transceiver
Popular Circuits
- USB communication circuit
- Indoor unit communication circuit
- Two-way communication circuit circuit diagram
- Long distance serial communication circuit
- CAN bus communication circuit
- Wireless transmitter circuit diagram
- Time division multiplexing stereo decoder circuit
- Design of wireless transmitting and receiving circuit based on Bluetooth
- Fiber optic transceiver circuit diagram
- Square wave generation circuit
