Touch type interlock electronic switch circuit
Source: InternetPublisher:天天都吃好吃的 Updated: 2015/07/24
The working principle is shown in the figure below. 74LS374 has a feature, that is, it can latch the D terminal state to the Q terminal at the rising edge of CLK (from 0 to 1); and the input high resistance characteristic of the CD4069 inverter is used to realize touch operation.
Normally, the RC at the input end of the inverter causes the output end to be 0. When the i-th input is touched (i=0, 1...7), the signals induced by the human body are transmitted to the Di end and CLK end of the 74LS374 respectively through the inverter: At this time, Di=1, so that the CLK terminal has a rising edge condition, so the state of the D terminal (except Di=1, the rest are 0) is latched to the Q terminal (Qi=Di=1), and the corresponding LED lights; when the signal If it disappears (meaning it is no longer touched), it will remain in its original state because there is no rising edge condition on the CLK end. Therefore, only one light will light up when touching, achieving the purpose of reliable interlocking and indicating electronic switch.
![触摸式互锁电子开关电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d0f2861e-3c63-11ec-8b1b-086126841eb8.jpg)
Latest Control Circuits Circuits
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- How to set up a cheap beam break sensor control distance scene using a reflector
- A small improvement to the temperature and water level indicator alarm
- Manual automatic air compressor control circuit
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and analysis of voice control circuit
- Do-it-yourself trial production of phase failure protection device
- Magnetic door and window anti-theft alarm
- Homemade short circuit alarm device
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
