AC and DC darkroom safety light circuit
Source: InternetPublisher:3228 Updated: 2019/08/25
This darkroom AC and DC dual-purpose lamp has a contactless automatic transfer switch function. Uses orange light-emitting diodes.
During normal power supply, AC 220 volts is rectified by bridge type of transformer, filtered by capacitor, and outputs about 4V DC (5V when no load). Because the battery voltage inside the machine is 3V, diode D is turned on, and the light-emitting diodes are powered by the rectified power supply. Since the BG emitter potential is lower than the base potential, BG is turned off, and the battery E in the machine is automatically turned off, and there is no current output. During a power outage, the BG emitter potential is higher than the base potential and is in a conductive state. Battery E supplies power to the light-emitting diode via BG. If the mains power is restored, diode D will be turned on again and BG will be automatically cut off.
Latest Control Circuits Circuits
- DIY a simple fire alarm
- How to use a microcontroller to control a servo motor?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to remotely control devices using ESP8266 and LPC2148
- An automated model railroad layout project using a microcontroller
- Motor automatic cycle control circuit
- Using P110C to control 6 DC motors simultaneously
- Add one more component to improve the phase failure protection function
- Simple three-phase motor phase loss protection circuit
- Night dog barking anti-theft reminder circuit
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
