Home >
Control Circuits >Automatic Control > Automatic opening and closing curtain controller circuit
Source: InternetPublisher:toothache Updated: 2017/05/03
The controller can automatically identify the brightness of the room and control the opening and closing of the curtains within the optimal bright and dark range of natural light. In Figure 1, the photoresistor RD and the time base circuit 5G1555 form the brightness recognition part. After the photoresistor RD receives natural light, its resistance changes and is set to RD1. At this time,
the components and parameters of RD1 in Figure 1 are as follows: BG1: 3DG12, BG2: 3CG14, BG3: 3DG12, BG4: 3DG12B. D1~D3: 2CP, D4~D7: 2CP14, DW: 2CW22C/100mA/7.5V. W1, W2: 100K, RD: 625 photoresistor, R1: 3K, R2: 3K, R3: 1.5K, R4: 150K. C1: 20μF/25V, C2: 0.01μF, C3: 100μF/25V, C4: 0.1μF, C5: 100μF/25V. When the black is turned on to a certain extent, the resistance value of the photoresistor RD increases. When the potential of ② pin of 5G1555 is less than 1/3Vcc≈2.1V, ③ pin outputs a high potential, BG2 and BG3 are cut off, and J2 is released. At the same time, D1 and BG1 are turned on, and J1 is closed. In Figure 2, the contacts J1-1 and J1-2 are closed, the motor reverses, and the curtain closes. When the curtain is closed in place, the limit switch a and b contacts are broken, causing the motor to stop. In addition, using another set of contacts of J1 to control the light controller can also achieve the effect of extinguishing or lighting up the light bulb while opening and closing the curtains.
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d133d5d4-3c63-11ec-9cdc-086126841eb8.jpg)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d1344b06-3c63-11ec-9cb0-086126841eb8.jpg)
Latest Control Circuits Circuits
- Tutorial for building a remote-controlled Arduino Air-Boat
- An automated model railroad layout project using a microcontroller
- What are the challenges in designing a permanent magnet linear generator?
- Working principle of one Xipu STR soft starter controlling two motors
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and production of no-load automatic power-off device for household power supply
- Ultra-short wave item left behind reminder alarm
- Precious home appliance anti-theft alarm
- Vibration anti-theft alarm circuit
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
