Homemade quick hand dryer circuit
Source: InternetPublisher:aytwartoofyoroo Updated: 2013/02/20
45. After washing your hands with the homemade quick hand dryer, put your hands under the quick hand dryer, and hot air will automatically blow out. After drying your hands, take your hands away and it will automatically turn off. The circuit is shown in Figure 2. When there is light, pin 1 of the IC is at high potential, TWH8751 is cut off, J is powered off, and J1-1 is disconnected. When the hand is inserted to block the light, D2 shows a large resistance, pin 2 of the IC is at low potential, the IC output terminal is turned on, J1-1 is turned on, the heating wire and motor are energized, and hot air is blown out. The power supply of the control circuit is obtained by a 36K resistor and a 2CP12 step-down rectifier to obtain a voltage of about +18V. The electric heating wire is 1KW and is spirally coiled under the motor. The main dimensions of the quick hand dryer shell and the arrangement of components are shown in Figure 1.
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d13c8886-3c63-11ec-b729-086126841eb8.jpg)
![](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d13cd6a6-3c63-11ec-adb2-086126841eb8.jpg)
Latest Control Circuits Circuits
- How to use a microcontroller to control a servo motor?
- Design of an autonomous plant watering system using ATtiny85
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- A small improvement on the ordinary refrigerator motor starting circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and production of radio remote control fan stepless speed regulator
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of the principle of automatic power-off switch during power outage
- Homemade short circuit alarm device
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
