Automatic dimming curtain circuit
Source: InternetPublisher:3228 Updated: 2014/01/23
Automatic "dimming curtains" can automatically adjust indoor lighting and are easy to use. The circuit is shown below. Photodiode D and R1, R4, R5 form a balanced bridge. When the light is appropriate, the potentials of points A and B are the same. Both are 1/2EC, and the potentials of pins 3 and 5 at the output terminals of the two KD28 operational amplifiers are also the same. The motor M does not rotate and the curtains remain in their original state.
When the outdoor light increases, the indoor light also increases, the internal resistance of the photosensitive diode becomes smaller, the potential of point A rises, the potential of pin 3 of the KD28 output terminal increases, the potential of pin 5 drops, the motor M rotates forward, and the curtain slowly closes until the indoor light weakens, and the resistance of D rises until the bridge is rebalanced. On the contrary, when the light weakens, the motor M reverses and the curtains slowly open. C1 and R6 act as a delay, which can slow down the control process and avoid repeated starting of the motor due to wind accidentally blowing open the curtains. The intensity of indoor light can be divided into three levels: strong, medium and weak. At night, even if the lights are turned on, the indoor lighting cannot meet the weak level requirements and the curtains will all be opened. If you need to close the curtains, you can turn the switch S to the "night" position. At this time, the potential at point A is always higher than the potential at point B, the motor rotates forward, and the curtains are closed. In addition, when the motor is in its two extreme positions (the curtain is fully open or fully closed), there will still be current. For this purpose, an extreme position self-stop switch must be installed, which is completed by contact point J and button AN. When the motor reaches an extreme position, J is disconnected and the power supply is cut off. When re-enabling, press AN, the circuit is connected and the curtain exits the extreme position, J is restored, and the control circuit can control normally again. The control circuit and battery can be installed in a small box and placed on the wall at a convenient location. Care should be taken to keep the photodiode at the top of the box and avoid direct light exposure. Since the extreme position self-stop switch is not difficult to design and install by yourself, it is omitted here.
![自动调光窗帘电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d1451424-3c63-11ec-b8c6-086126841eb8.jpg)
Latest Control Circuits Circuits
- Design of an autonomous plant watering system using ATtiny85
- Use your smartphone to turn on/off the power in your home
- Peripheral circuit of automotive motor controller power supply chip
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- What is a RADAX motor?
- Perform surgery on the speaker protection circuit
- DC motor drive circuit composed of L293D
- Design and analysis of voice control circuit
- Delay switch made with LM431
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
