Convert single power supply to dual power supply
Source: InternetPublisher:石榴姐 Updated: 2010/10/19
TDA2030 is a high efficiency operational amplifier. Using its complementary output stage, the unipolar power supply can be split into two and converted into the bipolar power supply required by some low-power circuits.
The circuit is as shown in the figure above. R1 and R2 with equal resistance form a voltage divider to make the voltages of the upper and lower parts equal. The midpoint of the voltage divider is connected to the non-inverting input terminal of the operational amplifier, and the operational amplifier is connected as a voltage follower to make the potential of the O' terminal and the O terminal equal. The O' terminal is a virtual point, and it must be isolated from the ground of the input power supply. If the bipolar power supply is taken out directly from R1 and R2, the internal resistance of the power supply will be large, the load capacity will be poor, and the practical value will be little. After using the operational amplifier, the two sets of output power supplies have very low internal resistance and the load capacity is enhanced.
![将单电源转换双电源](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d156a098-3c63-11ec-9334-086126841eb8.jpg)
Latest Power Circuits Circuits
- Schematic diagram of car cigarette lighter to USB power port
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- ISO113 circuit that can reduce power consumption
- Visible laser digital control modulation driver
- Dual forward converter schematic diagram
- Charging control circuit made by solar energy
- 3~15V 10A adjustable voltage regulated power supply
- Mc34063 MP3 Switching Charger
- Circuit diagram explanation: simple switching power supply circuit diagram
Popular Circuits
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
