Digital long delay circuit
Source: InternetPublisher:JFET Updated: 2019/09/23
General long delay circuits usually rely on electrolytic capacitors or high impedance circuits. This type of delay circuit has poor stability and low delay accuracy.
What is given here is a digital long delay circuit that completely abandons large electrolytic capacitors and high impedance circuits, and has high delay accuracy. The core of the circuit is the integrated block MC14521B, which is a 24-level frequency division circuit that contains an inverter that can form an oscillation circuit. If the trigger input terminal is grounded or no signal is added, the circuit enters the delay state, and the delay time is adjusted by the range switch X and the 100KΩ potentiometer. If X is connected to point A, the delay is 1 minute 40 seconds to 18 minutes 30 seconds, and if X is connected to point B, the delay is 13 minutes 20 seconds to 2 hours 28 minutes. When X is connected to point C, the delay is 1 hour 47 minutes to 20 hours. The specific delay time is set by the 100KΩ potentiometer. If a longer delay is required, a larger capacitor can be used instead of the 39nF capacitor. At this time, the delay can reach more than a week. Adding a positive signal to the trigger output will reset the frequency divider in 4521B. The delay is reliable and stable, and it is recommended to be powered by a 6-15V regulated power supply. The prototype is powered by a 12V power supply.
![数字式长延时电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d165bc00-3c63-11ec-bce8-086126841eb8.jpg)
Latest Control Circuits Circuits
- Design and selection of electric control valve system drive
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How to make a wheeled self-balancing robot using ultrasonic sensors
- A simple door handle touch alarm circuit
- How to set up a cheap beam break sensor control distance scene using a reflector
- One-way rotation circuit of motor controlled by contactor
- Add one more component to improve the phase failure protection function
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and production of wireless multi-location control switch circuit
- Infrared blocking alarm device
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
