a special power circuit
Source: InternetPublisher:赔钱虎 Updated: 2015/07/05
Although this circuit has a simple structure, it can generate three sets of DC voltages from two identical secondary windings, which are +5V, -5V and +12V required by some microprocessors. The characteristic of the circuit is the connection method of diodes D2 and D3. They are connected across the two sets of AC power supplies E2 and E3 and play a full-wave rectification role. In the positive half cycle, E2 charges C2 through D2, and the current path is b→C2(+)→C2(-)→D2→a; in the negative half cycle, E3 charges C3 through D3, and the current path is d→D3→C2 (+)→C2(-)→C. Diodes D1 and D4 form a general half-wave rectifier. The input voltages of the two three-terminal regulators 7805 are provided by C2 and C3 respectively, while the input voltages of the 7812 are provided by the positive addition of the voltages on C1 and C2.
Latest Power Circuits Circuits
- Analysis of the working principle of switching regulator
- Step-down power supply for driving relays
- Driving circuit that controls LED brightness using PWM signal
- LED Driver ZD1680
- Principles and precautions of active discharge circuit
- Current/voltage conversion circuit using current converter
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Power supply circuit that can reduce LM317 ripple
- Integrated regulated power supply with continuously adjustable output voltage
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
