Home >
Power Circuits >Switching Regulated Power Supply > Practical circuit of ringing switching power supply
Source: InternetPublisher:司马缸砸光 Updated: 2010/09/04
The picture below is a practical circuit of a ringing switching power supply. The purpose of the diode VD, resistor R and capacitor C connected to the primary winding Np of the transformer is to discharge the energy accumulated in the leakage inductance of the transformer. In other words, during the conduction period of the switch tube, the current accumulates energy in the leakage inductance, but this part of the energy is not transmitted to the secondary of the transformer as electrical power. Therefore, a reverse electromotive force is generated at the moment when the switch tube is turned off, and a very high surge voltage appears, which overlaps the collector voltage of the switch tube and easily breaks down the switch tube. If a diode and a resistor and capacitor are added, this part of the energy will be stored in the capacitor C through the diode VD and become DC, which can be discharged through the resistor R.
The main technical indicators of the power supply are as follows: Input voltage: AC 85~276V; Output voltage: 18V; Output current 2A; Working frequency: 20kHz; Efficiency: 75%.
![振铃开关电源实用电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/e5d49808-3c63-11ec-a1fc-086126841eb8.jpg)
Latest Power Circuits Circuits
- ISO113 circuit that can reduce power consumption
- Use pulse width modulation to get a precise output voltage
- Current/voltage conversion circuit using current converter
- Dynamic power supply for power amplifier controlled by thyristor
- 3~15V 10A adjustable voltage regulated power supply
- USB power socket using the car battery
- Electric bicycle battery charger circuit
- Production of backup power supply for cordless phone
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- MAX1811 Lithium Battery Charger Production
Popular Circuits
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
