Home >
Power Circuits >Switching Regulated Power Supply > Ringing switching power supply constant current drive circuit
Source: InternetPublisher:supremeOne Updated: 2013/11/03
In the ringing switching power supply, the loss of the drive circuit that supplies the base current of the switching transistor is considerable. In addition to ensuring that the switching transistor can fully conduct at the lowest input voltage, the voltage UB on the transformer coil NB is proportional to the input voltage Ui. When Ui rises, the drive current Id also increases, and the loss caused by the increased base resistance Rb increases with the square of the increase in Id. When the driving current ID increases, the current of the Zener diode branch will inevitably increase, which is likely to cause oscillation problems, that is, the switch will work in a certain period of time, and the switch will stop working in the next adjacent period of time. This cycle continues over and over again, and the oscillation frequency is approximately several hundred to several thousand hertz. To solve these problems, that is, when the input voltage changes, constant current driving can be used to keep the driving current basically unchanged, as shown in the figure below.
This is essentially a simple series regulator. Its load is a fixed resistor RB. Even if the input voltage Ui changes, the current flowing through RB is constant. This can not only greatly reduce the loss on the resistor, but also prevent intermittent oscillation. The power supply can work continuously and normally within the range of AC 100~200V.
Latest Power Circuits Circuits
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Build a simple buck-boost regulator and test it on a breadboard
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LED rechargeable flashlight circuit diagram
- Boost drive circuit composed of RT8450
- 3~15V 10A adjustable voltage regulated power supply
- MIC4680 constant current charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Practical constant current charger-----Constant current charger
- A low-cost, high-reliability battery charger for electric vehicles
Popular Circuits
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
