300kHz600WZVT--PWM boost converter
Source: InternetPublisher:桂花蒸 Updated: 2015/07/22
Using the power stage circuit as shown in the figure, a switching regulated power supply with a switching frequency of 300kHz, an output power of 600W, and an output voltage of 300V can be designed using the ZVT--PWM boost converter. Its input voltage is 150~200V.
Ls is a saturable reactor, used to eliminate the ringing between Lr and VT1 output capacitor, using Toshiba spike killer (Toshiba spike killer) SAl0×6×4.5 magnetic core, wound with 5 turns. Use fast recovery diode VD2 to prevent the VTl body diode from conducting. Without the diode, some current would be conducted to provide resonance between the Lr and VTl output capacitors. In this way, when VTl is turned off, it will suffer the reverse recovery problem. It should be noted that the auxiliary switch is chosen for a much smaller current rating than the main switch. The auxiliary switch here uses IRF730 (400V, 5.5A, 75W), and the main switch uses IRFP350 (400V, 16A, 150W). The circuit operates in zero-voltage switching within the input voltage and load ranges, with a maximum efficiency of 97% at full load and the highest input voltage, and the noise is very low, and the experimental waveform is consistent with the theoretical waveform.
![300kHz600WZVT--PWM boost变换器](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/e7f44bae-3c63-11ec-b28d-086126841eb8.jpg)
Latest Power Circuits Circuits
- Sharing layout and tips for multi-rail power supply design
- Driving circuit that controls LED brightness using PWM signal
- Detailed explanation of 5v charger circuit diagram
- Boost drive circuit composed of RT8450
- Charging control circuit made by solar energy
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage power socket
- Constant current charger using light emitting diode as voltage regulator
- Mc34063 MP3 Switching Charger
- Detailed explanation of mobile phone charger circuit diagram
Popular Circuits
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
