Metal halide lamp electronic ballast constant power control circuit diagram
Source: InternetPublisher:风向西瓜 Keywords: Electronic ballast integrated power supply constant power Updated: 2021/06/01
This circuit can increase the power factor λ of the system to above 0.99, effectively suppress the waveform distortion of the input power current iin, reach the distortion index lower than L level required by GB15144, and ensure that the current crest coefficient of the HID lamp is less than 1.7.
Connect the detection resistor Rs in series to the input end of the Buck circuit, and then filter it through the resistor R1 to obtain the average voltage signal. The voltage signal of the lamp is detected from the L2 end. The two amplify the voltage signal through EA, and the output voltage obtained is used as a feedback signal. The relatively strong input is to the PWM controller, and the PWM controller outputs a control signal Vf according to the input feedback voltage signal to control the duty cycle of the switch S2 of the Buck circuit. By appropriately selecting R1, R2, and R3, the output power Po can be well controlled.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Sharing layout and tips for multi-rail power supply design
- 5 Converter Topologies for Integrated Solar and Storage Systems
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Practical and convenient fax machine power supply control circuit
- What kind of circuit is a voltage regulator circuit?
- Basic circuit description of adjustable voltage regulator LM317
- Current/voltage conversion circuit using current converter
- Dynamic power supply for power amplifier controlled by thyristor
- Design of electric vehicle charger
- Old 20W electronic ballast circuit diagram
- Double tube energy saving lamp electronic ballast
- Fluorescent lamp electronic ballast circuit 2
- hid electronic ballast circuit diagram
- EW-8W electronic ballast circuit diagram
- Simplified electronic ballast circuit diagram
- Electronic ballast circuit diagram using thyristor
- Electronic ballast circuit diagram using L6569
- Electronic ballast circuit diagram with thyristor protection
- High pressure sodium lamp electronic ballast circuit diagram using IR2155
