Car engine tachometer circuit design
Source: InternetPublisher:王达业 Keywords: Motor control circuit engine tachometer Updated: 2021/02/14
The automobile engine tachometer introduced in this example is made of single-junction transistors and integrated operational amplifiers as main components.
Circuit working principle: The automobile engine tachometer circuit consists of a relaxation oscillator, a differential circuit, a comparison amplifier and an ammeter drive circuit, as shown in the figure.
The relaxation oscillator circuit is composed of resistors rl-r3, capacitor cl and single-junction transistor vu.
The differential circuit consists of capacitor c3 and resistors r4 and r5.
The comparison amplifier circuit is composed of an operational amplifier integrated circuit lc, resistors r6-rlo, capacitor c2, and diodes vdl-vd3.
The ammeter drive circuit is an electronic switching circuit composed of resistors rll-rl3, capacitor c4, potentiometer rp, thermistor rt, Zener diode vs and transistor v.
The pulse frequency signal obtained from the breaker contact s of the distributor controls the working state of the relaxation oscillator and the comparison amplifier. When the breaker contact s is turned on, the relaxation oscillator does not oscillate, ic outputs low level, v is in a cut-off state, and no current flows through the ammeter pa; when the breaker contact s is turned off, the relaxation oscillator oscillates Work, the generated oscillation signal is differentially processed by c3 and r5, and then added to the positive input terminal of ic through vdl, r6 and vd3, so that lc outputs high level, v is turned on, and +l2v passes through the c and e poles of v. and rp are added to the ammeter pa (the average current flowing through pa is proportional to the pulse frequency generated by the breaker contact s); the engine speed is indicated by the ammeter pa.
Component selection
rl-r13 all use 1/4w metal film resistors. rp chooses multi-turn potentiometer or synthetic membrane potentiometer. rt uses a negative temperature coefficient thermistor. cl-c3 uses monolithic capacitors or polyester capacitors; c4 uses cbb capacitors. vdl-vd3 all use 1n4148 silicon switching diodes. vs uses 1/2w, 5·6v silicon Zener diode. vSelect s8050 silicon npn transistor. vu uses btt3 type single-junction transistors. IC uses LM339 operational amplifier integrated circuit. pa chooses lma ammeter.
- Design of an autonomous plant watering system using ATtiny85
- Controlling LEDs with Node-RED in Raspberry Pi
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- A small improvement on the ordinary refrigerator motor starting circuit
- Working principle of one Xipu STR soft starter controlling two motors
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Simple phase failure protection circuit composed of intermediate relay
- One-way rotation circuit of motor controlled by contactor
- Guanghua brand anti-theft doorbell electronic lock circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Switching regulated power supply circuit
- Infrared voice control circuit
- Traffic traffic light control circuit
- High-rise residential walkway lighting control circuit
- Relay control circuitb
- Microwave heating component control circuit schematic diagram
- Automatic sprinkler irrigation control circuit
- Temperature detection control circuit of electric hot water bottle
- Small signal to large current photoelectric control circuit
