Non-isolated regulated converter development board, do you know?
Source: InternetPublisher:念慈菴 Keywords: epc converter non-isolated voltage regulator Updated: 2021/01/01
What is a non-isolated regulated converter development board? What does it do? The EPC9130 development board from EPC is a non-isolated regulated converter development board that converts 48 V to 12 V. It has five functions. With three phases, each phase has 12 A, and the maximum output current is 60 amps, the output power of the development board can exceed 700 W. The board features ultra-high power density (greater than 1250 W per cubic inch) and an efficiency greater than 96%.
The EPC9130 development board has five phases, includes two 100 V enhancement mode gallium nitride field effect transistors (eGaN FETs) EPC2045 in a half-bridge configuration and uses uPI Semiconductor's up1966A gate driver. The PWM signal sent to the gate driver is generated by the onboard Microchip dsPIC33 microcontroller. The board contains all key components in a layout for optimal switching performance – the bill of materials/cost is less than $0.06 per Watt.
Various emerging computing applications require more power and smaller form factors. In addition to the expanding server market, other applications include multiplayer gaming systems, fully autonomous cars, artificial intelligence and Bitcoin mining. Facing the requirements and challenges of these applications, EPC9130 greatly improves the power density of DC/DC converters that convert 48 V to 12 V while making the converters smaller and lower cost.
Alex Lidow, CEO of EPC Power Conversion, said: "The power density of this DC/DC system exceeds 1250 W per cubic inch, while the efficiency is greater than 96%, which is an unprecedented advantage for this type of power converter. The most attractive Remarkably, the component cost is less than $0.06 per watt, which is much lower than systems currently in production."
Please refer to the online quick guide we provide you about the EPC9130, including setup steps, circuit diagrams, performance curves and bill of materials. The above is the analysis of the non-isolated regulated converter development board, I hope it can help you.
- Sharing layout and tips for multi-rail power supply design
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Use pulse width modulation to get a precise output voltage
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Principles and precautions of active discharge circuit
- Adjustable regulated power supply with current limiting protection
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage power socket
- Practical constant current charger-----Constant current charger
- STR5412 power circuit
- Power circuit of STR5412
- Solar power circuit
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- Warm current power supply circuit b
- Transistor stabilized current power supply circuit 2
- Super Class A power amplifier power circuit
- Class A power amplifier power circuit
- Household emergency power circuit 02
- Inverter power circuit made with BJ50A
