Three-phase motor single-wire remote commutation circuit
Source: InternetPublisher:赔钱虎 Updated: 2020/01/30
In some occasions, it is necessary to control the starting, stopping and reversing operation of the motor at a place far away from the motor. The circuit shown in the figure is designed to adapt to this requirement. Set up a wire (single line) as shown in the figure and control the selector switch SA "offsite". When SA is set to position "1", the local motor stops; when set to "2", the local relay K1 forms a loop through VD3, ground wire, VD1, SA, transformer T, and single line. K1 acts, and its contact K1 Turn on the coil circuit of AC contactor KM1, and the motor will rotate forward; when SA is set to "3", relay K2 will act, AC contactor KM2 will act (KM1 loses power), and the motor will rotate reversely. The relay can be JRX-13F24V, and the transformer can be a 36V power transformer. Considering the long line and large voltage drop, the low-voltage output voltage of the transformer should be higher.
![三相电动机单线远程换向电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/4fb913f6-3c64-11ec-9068-086126841eb8.jpg)
Latest Control Circuits Circuits
- A simple magnetic switch circuit sharing
- Use your smartphone to turn on/off the power in your home
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- Introduction to the internal structure of the Delta winding motor
- Manual automatic air compressor control circuit
- Motor automatic cycle control circuit
- Motor control circuit for starting and running without phase loss
- Methods for Eliminating Noise of Brushed DC Motors
- Design and manufacture of three-phase motor protection circuit
- Password type motorcycle anti-theft device
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
