Bidirectional thyristor speed regulating circuit
Source: InternetPublisher:Lemontree Updated: 2018/12/07
The motor M is connected in series with the bidirectional thyristor VS. If the conduction angle of VS is changed, the AC voltage value applied to both ends of the motor M can be changed to achieve stepless speed regulation in the range of 0 to 220V. Generally, the trigger circuit of a bidirectional thyristor is relatively complex and uses many components. As shown in the figure, only one potentiometer RP is used to achieve the purpose of speed regulation. This uses an "equipotential trigger circuit", that is, whether it is a positive trigger or a negative trigger, the potentials of the control electrode G and the cathode T2 are the same. This circuit can be used for dimming and speed regulation of electric fans, incandescent lamps or other household appliances.
![双向晶闸管调速电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/513dbdd8-3c64-11ec-9f43-086126841eb8.jpg)
Latest Control Circuits Circuits
- Controlling LEDs with Node-RED in Raspberry Pi
- Peripheral circuit of automotive motor controller power supply chip
- How to build a simple tachometer using an infrared reflectance sensor
- Tutorial for building a remote-controlled Arduino Air-Boat
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- DIY an electromagnetic levitation device
- Manual automatic air compressor control circuit
- Design and analysis of voice control circuit
- Home wireless burglar alarm circuit
- Infrared detection alarm
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
