Home >
Power Circuits >Communication Power Pupply > Single-ended forward converter electrical schematic diagram
Source: InternetPublisher:抄写员 Updated: 2017/03/07
As shown in the figure, when the switch V1 is turned on, the input voltage Uin is all added to both ends of the primary coil W1" of the converter. The induced voltage generated on the demagnetization coil W1"" causes the diode V2 to cut off, and the secondary coil W2 The induced voltage turns on V3 and transfers the energy of the input current to the inductor Lo, capacitor C and the load; at the same time, a magnetizing current is established in the transformer. When V1 is turned off, V3 is turned off, and the polarity of the voltage on Lo is reversed. and continue to supply power to the load through the freewheeling diode V4. The magnetizing current in the transformer is released to the input power supply Uin through W1"" and V2 and is demagnetized; W1"" has a clamping effect, and the voltage on it is equal to the input voltage Uin. Before V1 is turned on again, the demagnetization current in T must be released to zero, that is, the magnetic flux in T must be reset. Otherwise, the transformer T will be saturated and V1 will be damaged. Usually W1"=W1"" is used, and a double line is used. The duty cycle of the parallel-winding coupling mode is <0.5, otherwise T will be saturated. The single-ended forward converter waveform is shown in the figure below.
Latest Power Circuits Circuits
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Step-down power supply for driving relays
- Basic connection circuit of signal and power supply composed of ISOll3
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Voltage-current converter constructed with XTR110
- A simple positive and negative power supply circuit
- Homemade low-power UPS
- USB power socket using the car battery
- Adjustable voltage regulated power supply circuit
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
