Water level alarm circuit diagram
Source: InternetPublisher:张三叔 Updated: 2018/08/07
This circuit will trigger with any fluid with a resistance under 900K between the maximum separation distance of the probes. Let me explain further. The circuit uses a 4050B CMOS hex buffer working on a 5 volt supply. All gates are biased off by the 10M resistors connected between ground and buffer input. The "common" probe the topmost probe above probe 1 in the diagram above is connected to the positive 5 volt supply. If probe 1 is spaced 1 cm away from the common probe and tap water at 25 ?C is detected between the probes (a resistance of 20k) then the top gate is activated and the LED 1 will light. Similarly if probe 2 at 2 cm distance from the common probe detects water, LED 2 will light and so on. Switch 1 is used to select which output from the hex buffer will trigger the audible oscillator made from the gates of a CMOS 4011B IC.
Placement of Probes:
As 7 wires are needed for the probe I reccommend the use of 8 way computer ribbon cable. The first two wires may be doubled and act as the common probe wire. Each subsequent wire may be cut to required length, if required a couple of millimetres of insulation may be stripped back, though the open "cut off" wire end should be sufficient to act as the probe. The fluid and distance between probe 6 and the common probe wire must be less than 900k. This is because any voltage below 0.5 Volt is detected by the CMOS IC as logic 0. A quick potential check using a 900k resistance and the divider formed with the 10M resistor at the input proves this point:
5 x (0.9 / (0.9+10) = 0.41 Volt.
As this voltage is below 0.5 volt it is interpreted as a logic 0 and the LED will light. If measuring tap water at 25 ?C then the distance between top probe and common may be up to 45 cm apart. For other temperatures and fluids, it is advisable to use an ohmmeter first. When placing the probes the common probe must be the lowest placed probe, as the water level rises, it will first pass probe 1, then 2 and fin
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Controlling LEDs with Node-RED in Raspberry Pi
- Build a glove-controlled robotic arm
- A simple door handle touch alarm circuit
- Motor automatic cycle control circuit
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Hydraulic control circuit design and analysis
- Simple three-phase motor phase loss protection circuit
- Homemade short circuit alarm device
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
