New USB speaker solution MK909D, 1W output power per channel
Source: InternetPublisher:supremeOne Updated: 2016/03/22
New USB speaker solution MK909D.
# Use the latest USB DAC chip, support USB1.1, USB2.0 interface.
# 48K DA sampling, built-in stereo Class D audio amplifier, 1W output power per channel, no longer the problem of low output power of other USB speaker solutions.
# Built-in 64-level volume control with memory function; supports three volume adjustment methods (A) touch button; (B) potentiometer; (C) encoder. Support output mute function.
# The peripheral circuit is simple: 2 10UF, 2 4.7UF, 1 2.2UF, 4 capacitors below 0.1UF, 4 resistors, 1 LED, 1 24M crystal. Due to the built-in stereo Class D audio amplifier, the output does not require Use large electrolytic capacitors for DC blocking, which is low cost.
# The status of the work indicator light can be selected between steady light and flashing.
# The IC is packaged in SOP28 with heat sink and is small in size.
- How to Build a Simple FM Radio Receiver on a Breadboard
- LM386 makes an AM radio
- Convenient and practical electric guitar wireless transmitter
- Pocket Wireless Microphone
- Superheterodyne receiving module circuit using RX3310A
- SB-200BRX superheterodyne receiving circuit
- GPS RF front-end circuit composed of MX2740
- RF2948B QPSK 2.4 GHz Spread Spectrum Transceiver
- RF2919 ASK/OOK 915/868/433 MHz Receiver
- RXM-433/418/315-LC-P AM Receiver Module
- USB communication circuit
- Indoor unit communication circuit
- Two-way communication circuit circuit diagram
- Long distance serial communication circuit
- CAN bus communication circuit
- Wireless transmitter circuit diagram
- Time division multiplexing stereo decoder circuit
- Design of wireless transmitting and receiving circuit based on Bluetooth
- Fiber optic transceiver circuit diagram
- Square wave generation circuit
