Field output circuit: TA8427
Source: InternetPublisher:司马缸砸光 Updated: 2011/06/28
TA8427
1 pin: 0V - ground
Pin 2: 14V - field output
Pin 3: 27V - field output stage power supply
Pin 4: 1.0V——Field excitation signal input
Pin 5: 0.6V - phase compensation
Pin 6: 27V - power supply
Pin 7: 1.9V - pump power output
- Sharing layout and tips for multi-rail power supply design
- The basic principles of power supply design. What are the key components of a power supply?
- Switching power supply circuit composition and function introduction of each part
- How to use SBR to improve power conversion efficiency
- Charging control circuit made by solar energy
- Power supply circuit that can reduce LM317 ripple
- 0.7~24V continuously adjustable current limiting power supply
- USB power socket using the car battery
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Practical constant current charger-----Constant current charger
- Excellent performance household inverter power supply circuit
- Output 12V-10A power supply circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Household emergency power circuit 02
- Common power circuits and applications 08
- Common power circuits and applications 03
- DC-DC conversion power supply circuit
- ±5V, ±12V power circuit A
