Water inlet motor protection circuit
Source: InternetPublisher:spectrum Keywords: power switch power supply protection Updated: 2020/08/21
![Water inlet motor protection circuit](http://www.eeworld.com.cn/circuit/upload/0cd8ddff183191b1bd12762d6c7e4d6f/61368a0f99fa34e9fe7d88fffb423e59.jpg)
When the start button SB2 is pressed, KM is powered and self-locked, and the motor M starts to run. If water enters the motor at this time and submerges probe A, A is connected to the casing through the water, relay K is closed, the normally closed contact is disconnected, KM loses power and is released, and motor M stops; at the same time, HA beeps Sound the alarm, notify the staff to eliminate the water source, cut off the power switch, and dry the motor.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Introduction and principle analysis of switching regulated power supply
- Basic circuit description of adjustable voltage regulator LM317
- ISO113 circuit that can reduce power consumption
- Op amp power supply decoupling bypass measures
- Visible laser digital control modulation driver
- Detailed explanation of 5v charger circuit diagram
- Adjustable voltage power socket
- Constant current charger using light emitting diode as voltage regulator
- Battery powered switching circuit diagram
- 24V power supply pure flat display high voltage power supply circuit diagram
- DC 12V to AC 100V inverter power supply circuit design
- 3v to 5v circuit diagram
- Typical Reference Voltage and Power Supply Circuits
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- Household emergency power circuit 02
- Music power circuit
- Common power circuits and applications 07
- Photoelectric remote control power switch circuit diagram
