Motor overcurrent protection circuit
Source: InternetPublisher:桂花蒸 Keywords: Power supply other power circuits Updated: 2021/01/02
Today we introduce the overcurrent protection circuit of the motor. When the motor starts, press the lock button SBi once. After the start is completed (after the motor speed is stable), press SBi again, and the protection circuit will start working. For motors with a short starting time (such as a few seconds), SBi can also use ordinary buttons, as long as the SBi is pressed during the starting process.
When the motor is running normally, the secondary induced potential of the current transformers TAi~TA3 is small and not enough to trigger the thyristor V. As shown in the figure below.
- Analysis of the working principle of switching regulator
- 5 Converter Topologies for Integrated Solar and Storage Systems
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How to Make a Soft Latch Circuit
- Using Lead-acid Battery as Power Source for Walkman
- Constant current LED lamp driver circuit with soft start and anti-shock
- The constant current source composed of two transistors can drive high power
- Dual forward converter schematic diagram
- Design of electric vehicle charger
- MAX1811 Lithium Battery Charger Production
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
