Simple three-phase power grid measurement interface circuit diagram
Source: InternetPublisher:太白金星 Keywords: Power supplyAC/DC Updated: 2021/05/12
Three-phase alternating current is a form of transmission of electrical energy, referred to as three-phase power. Three-phase AC power supply is a power supply composed of three AC potentials with the same frequency, equal amplitude, and phase differences of 120° from each other. Three-phase alternating current has many uses. Most AC power equipment in industry, such as motors, use three-phase alternating current, which is the often mentioned three-phase four-wire system. In daily life, single-phase power supply is mostly used, also called lighting power. When lighting electricity is used for power supply, one of the three-phase electricity is used to power electrical equipment, such as household appliances, and the other line is the fourth line of the three-phase four-wire, which is the neutral line. The neutral line is drawn from the neutral point of the three-phase electricity.
The figure below shows a simple three-phase power grid measurement interface circuit, which is mainly composed of 8031, SN74LS74, LM339 and other components.
![Simple three-phase power grid measurement interface circuit diagram](http://www.eeworld.com.cn/circuit/upload/31c21a89fa30adcb6d68ed5570358315/411abf2ea87961357640fd0e62193c16.jpg)
- Schematic diagram of car cigarette lighter to USB power port
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Single-power supply circuit for ISO122P/ISO124
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED rechargeable flashlight circuit diagram
- Detailed explanation of 5v charger circuit diagram
- Low cost and high performance LED constant current power supply
- An ultra-low output voltage regulator
- CNC regulated power supply production
- USB power socket using the car battery
- Principle of single live wire power taking circuit
- Commonly used soft start circuits for switching power supplies
- Thyristor-rectifier joint arm module three-phase half-controlled bridge rectifier circuit
- Zero-crossing trigger circuit design based on thyristor
- Power circuit b composed of intelligent thyristor modules
- Typical Reference Voltage and Power Supply Circuits
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Warm current power circuit a
- Low voltage adjustable reference power circuit
