Circuit design using TC35I wireless data transmission and GSM communication module
Source: InternetPublisher:国民男神经 Keywords: GSM circuit design communication module wireless data transmission Updated: 2020/06/03
Wireless data communication circuit design
Wireless data communication circuits are mainly responsible for the short-range wireless data exchange between motor vehicles and fixed base station systems. It consists of core chip nRF401 and its accessory components. nRF401 is a dual-channel, high-performance, low-power dedicated wireless communication chip with an operating frequency of 433.93/434.33MHz. The operating voltage is 3.3v and the maximum communication rate is 20kbps. It can be directly connected to the serial port of the microcontroller for asynchronous communication to achieve Data sent and received. No need to encode the data. The data input terminal DIN is connected to the TxD terminal of the microcontroller, and the data output DOUT terminal is connected to the RXD terminal of the microcontroller. In this circuit, the communication rate is designed to be 19.2 kbps. The circuit principle is shown in Figure 3.
![Circuit design using TC35I wireless data transmission and GSM communication module](http://www.eeworld.com.cn/circuit/upload/5ec6bef531d16b9c953634110b829640/1ed41d1d3cfe0cca38399ae164b2a167.jpg)
Transfer files for PCB proofing
Wireless data communication unit circuit
GSM communication module circuit design
The GSM communication module adopts SIEMENS' TC35I. TC35I is a special module specially designed by SIEMENS for GSM communication. It has voice, data, fax and point-to-point SMS functions. It works in the EGSM 900 and GSM 1800 frequency bands. It weighs only 10g and can operate normally within the range of 3.5~4.8V. The main instructions defined by AT Commands Interface Version 8.5 can be executed well, and there are more than 20 extended instructions.
The TC35I interface consists of 40-core cable. Among them, pins 1~5 are connected to the "+" terminal of the battery, pins 6~10 are connected to the "-" terminal of the battery, and pins 11~12 are the DC power input terminals, which can input 8~20V/500mA DC power. There is an automatic charging control circuit inside. The 15-pin IGT is for module startup control, and the 31-pin EMERGOFF is for shutdown control. They are both active at low level, and can also be turned on and off through commands. Pin 17 is the ringing output, pin 18 Rx is the serial data output, pin 19 TX is the serial data input, pin 32 is the working status indicator output, and pins 24~29 are connected to the SIM card. The interface circuit with the microprocessor is shown in Figure 4. The communication rate is 19.2kbps.
![Circuit design using TC35I wireless data transmission and GSM communication module](http://www.eeworld.com.cn/circuit/upload/5ec6bef531d16b9c953634110b829640/e6c10b463590b5499626e7b0b8b513fb.jpg)
Interface circuit between TC35I and microprocessor
All instructions for TC35I can be downloaded from the SIEMENS website. The vehicle-mounted user mobile payment system is composed of a low-cost AT89C4051 microcontroller with a working power supply of 3.3V. The base station is composed of a high-speed and high-performance 77E58-40 microcontroller to complete wireless data communication and identity authentication functions. CCD vehicle model identification is completed by another independent processing unit.
- Schematic diagram of car cigarette lighter to USB power port
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Basic circuit description of adjustable voltage regulator LM317
- Basic connection circuit of signal and power supply composed of ISOll3
- Transformerless AC-DC constant current LED driver circuit
- LED rechargeable flashlight circuit diagram
- A simple positive and negative power supply circuit
- Adjustable voltage power socket
- Constant current charger using light emitting diode as voltage regulator
- Adjustable voltage regulated power supply circuit
- Importance of Voltage Supervisors and Output Topology Selection
- Laser power circuit
- Solar power circuit
- EPSON PHOTO 830U printer power circuit
- Voltage stabilization control circuit in power circuit
- Power circuit with smoothing filter capacitor
- Super Class A power amplifier power circuit
- Remote control TV doorbell power circuit
- Common power circuits and applications 05
- High quality power supply circuit schematic diagram
