Transistor common base mixing circuit commonly used in FM radio frequency conversion circuits
Source: InternetPublisher:偷熊计划 Keywords: Frequency conversion circuit transistor mixing circuit FM radio Updated: 2021/09/18
For bands with higher carrier frequencies, the transistor common-base mixer circuit commonly used in frequency conversion circuits is shown in the figure. The transistor
in the picture can be 3AG33, which works in a common base state and is a commonly used frequency converter circuit in radios.
- Why does CAN FD communication need to enable TDC for sending and receiving delay compensation? How to configure TDC and SSP in TCAN4550?
- LM386 makes an AM radio
- A cheap and easy-to-make infrared TV signal repeater
- Homemade FM wireless microphone for teaching
- AM Transmitter
- Frequency modulation circuit for crystal oscillator stabilization in radio transmitter alarm
- MAX2366/MAX2367/MAX2368 I/Q 2000-1700 MHz/1000-800 MHz dual-band
- MC33493/D OOK/FSK 928~902 MHz/434~315 MHz dual frequency transmitter
- DKIOOOT OOK 315 MHz Transmitter Module
- Stereo FM transmitter circuit designed with BH1417
- Crystal controlled local oscillator circuit diagram
- Simple transistor inverter circuit diagram
- Humidity detector circuit
- Small FM radio circuit
- JSJ type transistor time relay circuit
- Transistor meter circuit e
- Transistor meter circuit c
- Three-phase motor phase failure transistor protection circuit
- The process and phase relationship of the driving signal from t1 to t2 (120° to 240°)
- Buffer amplifier with small back radiation
