Small FM radio circuit
Source: InternetPublisher:吃掉星星 Keywords: FM radio radio circuit resonant circuit transistor Updated: 2021/03/06
Shown is a small FM radio circuit. As can be seen from the figure, there are multiple resonant circuits . L connected to the antenna end and vc form
a resonant circuit. It resonates on a certain program carrier frequency of the tuned broadcast and is used to select the FM program of the radio station. The signal received by the antenna is frequency
selected by the resonant circuit and then sent to the base of the mixing transistor . At the same time, the local oscillator signal is also sent to the base of the mixing transistor.
There is also a resonant circuit L2 and vc in the base circuit of the local oscillator circuit transistor . It resonates at the local oscillator frequency, which is 10.7 MHz higher than the carrier frequency of the broadcast program. Mixing transistors
amplify the sum and difference frequencies of two signals. An LC resonant circuit (L3) is interleaved in the collector load circuit of the mixer amplifier transistor
The resonant frequency of L3 is 10.7 MHz. In this way , the difference frequency (10.7 MHz) of the first two mixing signals is selectively amplified through the La resonant circuit
, and
the RF signal is turned into an intermediate frequency signal and sent to the next stage intermediate frequency amplifier. After the intermediate frequency is amplified, the frequency discrimination integrated circuit extracts the audio signal from the intermediate frequency carrier
, and finally drives the speaker through the audio amplifier to restore the sound signal.
- AM Transmitter
- Frequency modulation circuit for crystal oscillator stabilization in radio transmitter alarm
- MICRF011 00K 440~300 MHz Receiver/Data Demodulator
- MAX23691/Q 2000-800 MHz Dual-Band Tri-Mode Transmitter
- SB-200BRX superheterodyne receiving circuit
- RX3310A Receiver Module
- MC33493/D OOK/FSK 928~902 MHz/434~315 MHz dual frequency transmitter
- rfPICl2C509AG/509AF ASK/FSK 480~310 MHz with 8-bit microcontroller transmitter
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- F05A/B/C Series AM 433/315 MHz RF Transmitter Module
- Simple transistor inverter circuit diagram
- Inductive feedback oscillator circuit
- Laser power circuit
- JSJ type transistor time relay circuit
- Transistor withstand voltage measuring instrument circuit a
- Transistor meter circuit e
- Distributed parameter microstrip circuit
- Tuning circuit for FM radio circuit
- Application of field effect transistors in pocket radio circuits
- Can type FM radio circuit diagram
