Mixing circuit composed of integrated analog multiplier (MC1496)
Source: InternetPublisher:公子李 Keywords: Analog multiplier mixing circuit MC1496 Updated: 2020/04/01
At present, high-quality communication receivers mostly use diode ring mixers and mixers composed of dual differential pairs of balanced modulators. The mixing circuit
composed
of an integrated analog multiplier ( MC1496 ) is shown in the figure.
The local oscillator voltage HL and the input signal voltage are input from the input channel respectively, and the 50kfl potentiometer is adjusted to make the DC potential difference between pins ① and ④ zero.
In addition to the input signal voltage P and the local oscillator voltage R, there are also interference and noise signals acting on the mixer. Any two of them
may produce a combined frequency. If the frequency of these combined signals is equal to or close to the intermediate frequency, it will pass through the intermediate frequency amplifier and demodulator with the input signal,
causing interference to the output stage and affecting signal reception, which is inevitable. The ground will cause interference, the most influential of which are intermediate frequency interference and image interference.
The intermediate frequency signal (9MHz) is taken out from the special band-pass filter after the single-ended output of pin ⑥.
- Transmitter Receiver Circuit for 80 Meter Amateur Radio
- How to Build a Simple FM Radio Receiver on a Breadboard
- Homemade modified machine with 4 LNB inputs and audio and video outputs
- FMA9901A FM broadcast dedicated antenna
- FM transmitter in a matchbox
- 1W FM Broadcast Transmitter
- GPS RF front-end circuit composed of MX2740
- nRF401/nRF403433/315 MHz Transceiver
- Rolling code radio transmitter circuit (HSC360/TDA5100)
- RCV420 4~20mA Precision Current Loop Receiver
- Mixer built with analog multipliers
- Transistor common base mixing circuit commonly used in FM radio frequency conversion circuits
- Mixing circuit composed of integrated analog multiplier (MC1496)
- Product type phase frequency discriminator circuit diagram composed of MC1496 (quadrature frequency discriminator) (4.5MHz)
- Wide dynamic range mixing circuit
- Mixing circuit
- Indoor unit communication circuit
- Amplitude modulation detector circuit using ULN2209 and MC1496K
- Precision analog multiplier circuit diagram
- CAN bus communication circuit
