Single pulse stretching circuit b
Source: InternetPublisher:D先生 Keywords: Single pulse monostable trigger pulse width Updated: 2020/09/17
Shown is a single pulse stretching circuit consisting of a monostable flip-flop CD4528 . When a narrow pulse is input to the monostable trigger
, there will be a wide pulse at the output. The output pulse width Tw can be adjusted by cx and Rx. The pulse width can be calculated as Tw≈0.69RxCx
- A simple magnetic switch circuit sharing
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- A simple door handle touch alarm circuit
- How to set up a cheap beam break sensor control distance scene using a reflector
- Working principle of one Xipu STR soft starter controlling two motors
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- IGBT modules block overcurrent by controlling the gate
- Temperature control circuit design and analysis
- Photocell amplification control circuit
- time control circuit
- Electromagnet control circuit
- High-rise residential walkway lighting control circuit
- Typical operation display circuit
- Timing and fire power control circuit
- Small power electric heater temperature detection control circuit
- Rechargeable front memory circuit
- D flip-flop type single pulse generator
- Monostable trigger pulse keying pulse source circuit diagram
