CD1316 tuning and demodulation circuit internal structure block diagram
Source: InternetPublisher:宋元浩 Keywords: Demodulation circuit demodulator BSP Updated: 2021/03/13
The company's integrated tuner- demodulator CD1316 has a digital programmable phase-locked loop (PLL) tuning system that can
control frequency selection and channel conversion through the I2C bus. The tuning voltage in the tuner and demodulator is provided by its own DC-DC converter, so only one
5v voltage is enough. The internal structure block diagram of the CD1316 tuning and demodulation circuit is shown in Figure 5-9.
The CD 1316 tuner-demodulator also contains an active splitter that splits the incoming RF signal energy into two parts. The splitter
supplies power to the tuner and demodulator in bypass mode alone. After the power is turned off, the splitter can still output signals normally. The 4 MHz PLL crystal reference frequency inside the tuner and demodulator
can be used as a reference signal to generate a local oscillator signal. The tuner- demodulator provides a balanced IF output that can directly drive a surface acoustic wave
(SAW) filter to a digital processing chip.
- Why should RS-485 transceivers be terminated? How to terminate?
- Analysis of the reasons why bow-tie antennas are preferred over microstrip antennas for 5G antennas
- Production of a FM wireless microphone
- The production of a crystal oscillator frequency-controlled broadband FM transmitter
- S9018 single tube super regenerative FM receiving circuit
- FM transmitter in a matchbox
- RF2948B QPSK 2.4 GHz Spread Spectrum Transceiver
- MAX2900/2901/2902 BPSK/ASK/OOK 915/868 MHz Transmitters
- rfHCS362G/362F ASK/FSK 440~310 MHz KEELOQ Code Hopping Transmitter
- MICRF500 FSK 1000~700 MHz Transceiver
- Electronic anti-asthma circuit
- High-efficiency speaker circuit for rural stage
- Particle clogging alarm circuit of wheat seeder
- Egg heating control circuit
- Poultry warming temperature control circuit
- Double detuned loop frequency discriminator circuit
- Simple AGC circuit in transistor radio
- base amplitude modulation circuit
- Schiller oscillator circuit
- High and low frequency signal generator circuit
