Remote control coded infrared transmitter circuit
Source: InternetPublisher:containsmachine Keywords: Coding remote control infrared transmitter transmitter circuit Updated: 2021/03/03
Shown is the remote control coded infrared transmitter circuit. The circuit is composed of three parts: infrared remote control keyboard matrix circuit, M50110p infrared remote
control transmitter integrated circuit and amplification drive circuit.
Its core circuit is the IC01 M 50110 P infrared remote control transmitter integrated circuit. Its ④~⑩ pins are externally connected to the keyboard matrix circuit, that is, the manual command
input circuit. After operating the keys. The ICOI@ pin outputs the remote control command signal, which is amplified by Qoi and Q02 to drive the infrared light-emitting diode Dot~
D∞ to emit the infrared light remote control signal.
K01 is the buzzer and Q∞ and Q¨ are the buzzer driving transistors. When the signal is transmitted, the buzzer will sound to indicate that the signal has been transmitted
- How to Build a Simple FM Radio Receiver on a Breadboard
- TA7792 Medium Wave Radio Circuit Diagram
- A cheap and easy-to-make infrared TV signal repeater
- MAX2820/MAX2821 I/Q 2.5-2.4 GHz Transceivers
- MICRF011 00K 440~300 MHz Receiver/Data Demodulator
- MAX23691/Q 2000-800 MHz Dual-Band Tri-Mode Transmitter
- RXM-433/418/315-LC-S Series Receiver Modules
- RF2909 GMSK/QPSK/DQPSK/QAM 915 MHz Transmitter
- Rolling code radio transmitter circuit (HSC360/TDA5100)
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- U-band 4 data signal wireless transmission circuit (PT2262)
- Remote control circuit a composed of TDC1808
- Remote control transmitting circuit
- Robot wireless remote control transmitter circuit
- Common transmitter circuit
- Radio frequency remote control switch transmitter circuit
- Magnetic induction transmitter circuit diagram
- MN6014/S infrared remote control transmitter circuit
- M58480P/M58484P (TV and audio equipment) 30-function infrared remote control transmitter circuit
- M708 (TV) infrared remote control transmitter circuit
