Multi-core cable breakage detector circuit
Source: InternetPublisher:aytwartoofyoroo Keywords: Detector cable BSP Updated: 2021/06/04
Shown is a multi-core cable breakage detector circuit. This circuit can check multiple wires at the same time to quickly and accurately detect
whether and which wire is broken in the cable
- especially suitable for telecommunications maintenance personnel.
The circuit is mainly composed of a self-excited oscillator (composed of a capacitor
cl, a resistor and transistors VTI and
VT2), a pulse distributor CD4017 and
an indication circuit . When in use, one end of the cable to be tested should
be grounded, and the multi-strand wire ends at the other end should be connected to the YO~Y9 output terminals of the detector
respectively
. After the pulse signal output by the self-oscillator
is processed by CD4017, a high level is output from its YO-Y9
to provide operating
voltage for the light-emitting diode. When the wire under test is intact,
the positive and negative electrodes of the light-emitting diodes are at the same potential ( the resistance of the cable is very small), and LED1 to LED10 do not light up. If a wire is broken, one end of the light-emitting
diode will be The current resistor is connected to high potential and the other end is connected to ground, so the corresponding light-emitting diode is lit, so that all the wires can be
inspected quickly.
- Fire safety evacuation emergency signs
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- USB powered portable light
- DCD-1240 multifunctional rechargeable lighting
- Six LED stereo VU display circuit built with IC LM3915
- Design and production of digital number answering machine
- Driving circuit for driving light-emitting diodes by IR53HD420
- Infrared remote control dimmer light circuit
- Photoelectric adjustment circuit
- Simple sensor alarm
- Set timing circuit when power is on
- Excellent performance household inverter power supply circuit
- Pulse therapy circuit
- Rice mill circuit
- Rural fish farming control circuit
- Straw returning to field crusher circuit
- Audio function generator composed of ICL8038
- Crabo oscillator circuit
- Capacitive feedback oscillator circuit
- Sine wave signal generator circuit
