pulse counter circuit
Source: InternetPublisher:国民男神经 Keywords: Pulse counter counter circuit BCD Updated: 2020/10/23
Shown is a pulse counter circuit. IC I is the BCD adding counter CD4518. It has two clock input terminals CP
and EN. When the rising edge of the clock is used to trigger counting, the counting pulse should be input from the CP terminal, and the EN terminal should be connected to high level, and the clearing terminal Cr should
pass Resistor Ri is held low to ground. IC2 is a BCD-seven-segment latch code, driver CD4543, which is used to decode the binary
BCD code output by IC1. Make it work as a seven-segment stroke code, and then drive the digital tube IC3 to display the counting result. The LD terminal of IC2 is the latch control
terminal, and it should be connected to high level. In this way, with the continuous input of counting pulses, IC3 will display the counting results.
Cl and Rl in the circuit form a differential clearing circuit, so that when the circuit is powered on, the positive pulse generated by the differential circuit clears IC 1.
When the circuit works normally, Ci. Ri will have no effect.
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- Types and structures/characteristics/functions/implementations of smart sensors
- Ceramic filter structure/working principle/characteristics/application
- Build a musical fountain using Arduino and sound sensor
- Structural diagram and function of sliding resistor
- Summary of knowledge points of multiplexer
- What is the difference between high-side and low-side resistive current sensing
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- LED Night Light
- Circuit diagram of an example of differential and integral circuits
- Meiling BCD - 191 type refrigerator circuit diagram when the switch is closed
- Far East brand BCD-185 refrigerator circuit
- Changling-Ariston BCD-180 three-door refrigerator circuit
- Kana brand BCD-223 refrigerator circuit
- Kana brand BCD-220 refrigerator circuit
- Hualing brand BCD-178W, BCD-182W refrigerator circuit
- Aerospace brand BCD-222 refrigerator circuit
- Phoenix BCD-190, BCD-195 refrigerator circuit
- Simple light-controlled pulse counter circuit
- Two-digit BCD addition and subtraction arithmetic unit
