Isolated RS-485 interface circuit
Source: InternetPublisher:三月小雨 Keywords: Interface circuit RS-485 interface data transmission Updated: 2020/03/04
The isolated RS-485 interface circuit is shown in the figure. This circuit can
isolate and transmit the serial data of the RS-485 interface, and the transmission is bidirectional.
The circuit is mainly composed of bidirectional transmission, dual isolation amplifier JS0150 and bidirectional transceiver LTC1485. IS0150
transmits data when R/T2A (receive/transmit) = o and R/TIA (receive/transmit) = o. At this time, the D2A end data is transmitted
to D2B, and the DIA end data is transmitted to DIB; R/T2A (receive/transmit) )=1, receive
data when R/TiA (receiving/transmitting)=1, at this time the D2B end data is transmitted to D2A. DiB side data is transmitted to Dl^. Whether IS0150 transmits or receives data
is determined by the level of DF and /RE terminals. The signal is isolated and transmitted by IS0150, and then further buffered by LTC1485 before output. The bidirectional
transceiver LTC1485 works on the same principle as the IS0150, but it does not isolate the transmitted signal.
- Which one is better, NPN or PNP transistor?
- How to identify common mode interference? Methods to eliminate common mode interference
- The Importance and Ideal Model of Impedance Matching
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- What are the types of commonly used batteries?
- What is the difference between CPLD and FPGA?
- What are the parts of the fpga design process
- Working principle and truth table of JK flip-flop
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Switch signal input interface circuit
- Interface circuit between AD574A and PC bus
- CPU and decoding chip memory, SD memory card socket interface circuit
- Calendar and clock display interface circuit
- TTL logic level interface circuit composed of LM311
- MAX225-RS232 multi-channel data interface circuit (driver-receiver)
- Interface circuit between CMOS and NMOS a
- Interface circuit between CMOS and ECL a
- Interface circuit between CMOS and switching amplifier c
- Power supply coupler-thyristor interface circuit c
